Send a message via AIM to splashloft
Question will '85 engine, trans & rear fit my '89 325i Convertible
I need a quick answer if it is possible because I have to get back to a guy shortly if I am to purchase this '85 for parts.
I need to know if the engine, transmission and rear of a 1985 325i coupe will go into my 1989 325i Convertible?
Thanks for all your help in advance.
Sandy
Regards,
Sandy
1973 2002 Tii
1974 2002
1984 318i (2)
1987 325i Convert.
1989 325i Convert.
1989 325i (2)
Old 03-15-2007, 07:21 AM
Yes. However the 85 is an eta (2.7l m20b27) and your 89 is a 2.5l (m20b25).
Keith
87 325i
96 328is
85 318
Old 03-15-2007, 07:48 AM
Keith,
Thank you for your reply, but can you put that in plan English? I only know how to put oil in an engine. I hate to admit that, but it is true.
I've been looking for a used engine, tranny and rear for an '89 325i convertible that I purchased to fix my '89 325i automatics tranny in the fall. Now I want to get the convertible running so I need "STUFF" for that now and don't know what years and models are compatible.
Regards,
Sandy
1973 2002 Tii
1974 2002
1984 318i (2)
1987 325i Convert.
1989 325i Convert.
1989 325i (2)
Old 03-15-2007, 08:53 AM
Exclamation
no no no no...don't waste your money. The parts car is a 325e, your convertible is a 325i. Although the engine will technically bolt in, alot of parts would be incompatible - fuel system components, even the ECU. The "E" engine is considerably less powerful, it's rated around 120hp while an "I" engine is around 170hp. Basically, you would be downgrading the whole car. It would also be worth next to nothing in resale value, a BMW fan can tell an E motor from an I motor just by looking.
I do what I want.
Old 03-16-2007, 09:09 AM
