LinkBack Thread Tools Rating: Thread Rating: 5 votes, 2.60 average.
Cool E36 Denso A/C compressor oil
I plan to rebuild the R134 Denso A/C Compressor in my E36. The compressor requires ND-Oil 8. What is ND-Oil 8? How does this compare to PAG oils? I want to make sure that I am using the same oil that it currently in the system.
Old 04-25-2007, 11:04 AM
Check this post:
http://www.autoacforum.com/messageview.cfm?catid=2&threadid=14912
The host of the forum can take care of you:
http://www.ackits.com/merchant.mvc?Screen=CTGY&Store_Code=01&Category_Code=Compressoroils
Source for parts (not sure which car you have, search their site):
http://acsource.net/xcart/home.php?cat=436
Note that many of the parts required for a complete rebuild aren't available to the general public. If you've never had a compressor apart, they are complex. Getting parts (other than valve plates, gaskets & clutches) is very difficult. Tolerances are critical & the dimensions are not typically available unless you're an OEM certified rebuilder.
Old 04-27-2007, 06:28 AM
