1996 328 Timing change interval
How often do you change a timing chain on a 1996 328i convertible..?
Thanks for any help !!! |
It should last quite a while. My '97 with 275k on it is all original. However, my other '97 with 150k has suddenly developed a nasty noise that I suspect may be a chain guide. If I go in there to replace the guides, I will probably replace the chain.
