-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   newbie - short shifter help needed (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/354180-newbie-short-shifter-help-needed.html)
sikosid 06-26-2007 04:34 PM
Hi guys,
I found a link on e36coupe.com with this site.
I have read the following on here -
If you have an E30 or E36 318, 325 or 323, then you can swap in the BMW E46 325Xi lever (part number BW-25-11-1-434-148, about $55) to obtain a 29% reduction in the shift throw.
Basically i have a 318i SE 1996 M43 saloon. I just wanted to confirm it is a direct swap.
If anyone has any info it would be great. Alos is the part numer the same in the UK bmw dealers?
Jeron 06-26-2007 07:06 PM
Look here some great pics and info:
http://www.unofficialbmw.com/ronstygar.html
sikosid 06-27-2007 03:42 AM
thanks for the reply, but i think thats for the z3 shifter.
Im looking to find out if the e46 325Xi short shifter will be a direct swap on my 318i SE m43 loon with no bending/modifications.. I'll be getting my mechanic to do it so i need it to be a direct swap.
I found the info on this page -
http://www.pelicanparts.com/bmw/techarticles/E36-Short_Shift/E36-Short_Shift.htm
Which is better for my car? The 328i/m3 lever or the 325Xi lever?
sikosid 06-28-2007 11:08 AM
Bump..
Can anyone confirm if either will fit my car and which one is better?
dfrost 06-28-2007 11:24 AM
I can't answer your specific question, but I recently had my shift linkage rebuilt with stock parts (didn't ask for anything different). The shop (not a dealer) that did the work replaced the lever along with bushings, etc. The result is 30% shorter throws (3-4 was 135mm, now 95mm) and effort is still very nicely light. I'll check the new lever P/N if desired (think I can read it beneath the shift boot).
sikosid 06-28-2007 02:11 PM
/\/\/\ Thanks mate
P.s is he guy who wrote the above page on this site? maybe i can ask him?
Wayne 962 06-29-2007 12:04 PM
I haven't personally installed that shifter in the car, so I don't know the *exact* answer to your question. If you are having a mechanic install it (not yourself), and you don't want any issues with that (and potentially be charged more in case it doesn't fit), then I would just bite the bullet and buy a short shift kit that is guaranteed to work with your car...
-Wayne
dfrost 06-29-2007 04:47 PM
sikosid,
For what it's worth, here's the P/N for the shift lever used in my recent linkage rebuild:
25-11-7-527-247
When I did a search on that P/N at Pelican Parts, it came back with the stock shift lever for all 325's.
