E36 M3 Clutch Probelem!
Hi,
Need some pointers on my clutch. The clutch pedal does not have resistance until it travels about half the distance down but does return to the normal position. This gives me problems engaging the gears obviously. Does this sound like the Master or the Slave cylinder? The clutch is fine, the problem started about 2 weeks ago and has gotten worse every day... I tried bleeding the system but no luck.
thanks,
frank
Old 03-28-2008, 06:36 PM
