HELP! E30 Electrical Problems
The instrument cluster on my 87 325 stopped working.
I replaced the NiCad batteries on the maintenence cluster board. Now the Tach and fuel economy gauge only work for about 5 seconds after the car has been started, then go dead. ALSO the heater fan only works for the first 5 sec after startup. Any suggestions? Last edited by ryanful; 07-04-2007 at 08:49 AM.. |
Someone must have some ideas.
What runs for only a short time after engine start? |
help me...
...please |
Hey man, check your fuses, mine was doing the same thing. I can't remember what 3 the guy told me to check, but you need to pull them out and check them. I tried to check the fuses in place with a fuse checker that came in the box of fuses and they checked out ok, I pulled them and checked them individually and found the problem. If I find the forum I'll let you know which 3 to check.
Electrical
That would be a HUGE help! Thanks |
So...
What only runs for a few seconds after start up and is linked to the ignition switch? |
