92 325i wont start
I recently had to replace my radiator because the post where the upper hose attached to the radiator broke off. I had been having overheating issues which might have been caused by this fault. I followed all the instructions from Wayne's amazing book, got the new radiator in and attached all the hoses. When I tried to start the car, it wouldn't. The engine is turning but not catching.
What could be the reason for this? HELP!
Old 09-14-2007, 03:40 AM
Jeron's Avatar
How long was the car down? I would start with the battery.
Does it make any noises? Engine turn over strong? Did you replace or remove anything besides the radiator?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-14-2007, 11:34 AM
The car was down for 3 days. The interior lights are still bright, not dim and there are no unusual sounds. When I turn the ignition, it tries to start but never gets going. Both the alternator and starter motor are less than a year old.
Is it possible there are wet wires that would prevent the car from starting?
Old 09-14-2007, 10:12 PM
Wet or loose wires might be the problem, is the ignition module close to the radiator, perhaps that got wet, or the ignition wires themselves? Try to get it totally dry by using compressed air.
Old 09-15-2007, 04:03 AM
Does the fuel pump buzz for a couple of seconds when you turn the ignition on, this is best heard with the doors and bonnet open.
Old 09-17-2007, 10:17 AM
Jeron's Avatar
Describe "tries to start but never gets going". Does it have trouble turning over or does it turn over strong but does not fire?
Old 09-17-2007, 01:18 PM
I have this same situation. Ran Peake and got code A1 which translates to the B+. Ride Cranks strong but no sound from fuel pump. exchanged pump and relay and still no turn-over
Old 10-02-2007, 12:57 PM
Jeron's Avatar
Check for power at the relay and at the pump.
Old 10-03-2007, 10:57 AM
Thank you for your intrest
I have time this weekend and will let you know.
AGAIN THANK YOU for your attention
Old 10-05-2007, 08:45 PM
Quick additional situation - prob!!!
My MAF is missing
Will my car still start... Understood that it will not be pretty - or quite
Old 10-05-2007, 08:47 PM
No power to relay or pump.
Old 10-11-2007, 11:27 AM
