93 325i rear axle noise
Any suggestions on how to differentiate between a bad rear wheel bearing and cv joint? I have the vibrating/whirring noise fairly constantly on left side, gets louder when turning one way- quits when turning the other. While under the car, I thought the sound was coming from the outer cv joint, but another opinion said the bearing. It's really hard to tell, although I am leaning toward the bearing as the culprit. Also, does anyone have instructions on replacing the bearing if that is the case? The car has disc brakes in the rear. Thanks!
Old 10-12-2007, 06:46 AM
When my rear wheel bearing started to go, it made a "whup-whup-whup" noise when turning in the direction that would put lateral loads on the bearing (right side when turning left). I never did find any DIY repair instructions, but it was headed into my local BMW garage for some service anyway. As I recall, the cost was about $500 for both sides.
The CV joint would be suspect if the boot has torn, AFAIK.
David Frost
Formerly smitten by a 1993 325i Sport with 170K+ miles. Now infatuated with an Audi A3 2.0T DSG.
Old 10-12-2007, 09:10 AM
Just got done installing a new rear wheel bearing and axles on my 1992 325i .
Before you start with these steps remove your sway bar and muffler .I'll give you the steps sounds easy but it takes aleast 2-3 hours (each side):
Tools needed : 13 mm wrench ,12 mm wrench,30 mm 12 point socket , 15 mm wrench , E14 Torx, side hammer, bearing press tool, gas torch, If your a rookie dont try this.
1 remove wheel
2 remove brake caliper
3 remove brake rotor
4 remove alxe
5 remove rear hub
6 remove wheel bearing
7 install new wheel bearing
8 install rear hub
9 install axle
10 install brake rotor
11 install install caliper
12 install wheel
Old 10-12-2007, 01:07 PM
