noise in rear of 96 328IS
I'M HOPING I'M L@@KING AT A DEAD/NOISY AXLE BEARING IN THE ' REAR TRAILING ARM!
i've printed off the rear axle bearing post. NO MENTION OF ANY SPECIAL
TOOLS! can i safely ASSUME this 'chore' can be 'accomplished' in my driveway?
the narrative and looking at the exploded view---'i have arrived at the conclusion'--- push the axle out of the bearing w/ a puller, remove the snap-
ring, drive the old bearing out of the trailing arm and drive the replacement bearing into place, pull the axleshaft thru the bearing and re-assemble, 'reverse of the dis-assembly'--- AM I GETTING THE WHOLE PICTURE?
thanx----red---- a.k.a. larry
Old 11-13-2007, 09:39 AM
Jeron's Avatar
I've never done a wheel bearing, but I expect too soon because as soon as someone asks about something I haven't done that same part fails on my car.
All I've heard about bearing replacement is you need a big breaker bar to get the nut loose.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-13-2007, 10:35 AM
I have done them several times to e30 and e36. Getting the stub shaft out can be a real problem. The splines on the stub shaft are tapered, when you tighten the shaft nut it pulls it into the bearing. I use a stub shaft puller. (its actually a press). it bolts to the hub and pushes the shaft out. Other than that its not too bad.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 11-14-2007, 05:07 PM
Mission Accomplished!
NOT A JOB FOR THE FAINT OF HEART--- or on-the-driveway! WITHOUT A HOIST AND PRESS i would have been on-the-job more than the EIGHT HOURS it took to complete the CHORE!
admittedly replacing the driver's side WITHOUT removing the exhaust system
is the MOST DIFFICULT side! [my advice do both sides at same time, passenger side is my near future 'chore.']
MITCHELL-ON-DEMAND estimator qoutes both sides at 5 hours, PELICAN PARTS rates the 'chore' as 6 out of 10----real world without the BMW specific on-the-car tools, figger to start EARLY and finish LATE! much LATER!
this is my son's car, his word's----either i buy a newer BMW next time or one with the 'mileage-specific-repairs ALREADY DOCUMENTED/COMPLETED!
I'VE DRIVEN 240 VOLVOS FOR MANY YEARS, BY-COMPARISON THEY'RE MUCH EASIER TO WORK ON!
thanx---red--- a.k.a. larry
Old 11-20-2007, 07:05 AM
