-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Check control messages (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/379953-check-control-messages.html)
911sculler 11-29-2007 02:51 PM
I am getting a check control message that says "brake light circuit - check owners manual". The owners manual doesn't cover this particular phrase and neither does my Bently manual. What does this mean? Is this a bulb failure or something more concerning? The car is a 1997 328i Sedan with automatic transmission. Please help...
Yurick 11-29-2007 05:53 PM
I would check the obvious first - brake lights.
whosyadadie01 11-29-2007 09:10 PM
i got a similar message of brake light failure ... all the lights work just dont no why it says it ... seems to be a common problem with some on the e36"s
grafhky52 11-30-2007 03:39 AM
if it says brake light circuit you need a brake switch. and for the brake light failure if all lights are working pull each one out and see if the bottom of the bulbs are burnt or the sockets.
whosyadadie01 11-30-2007 05:44 AM
all the lights work but i had to do a little repair job on one of the lights being that one of the contacts got melted and i had to bypass it with a peice of wire lol ..... and 911sculler i dont mean to steal your thread just trying to get my problem adressed at the same time
Silvercat 11-30-2007 10:28 AM
I've had it happen a couple of times - and after searching various forums I've just ordered the switch! Seems to be a fairly common problem.
SCOTITUDE 12-01-2007 01:45 PM
BTDT. common problem. you need a brake switch. its above the brake pedal under the dash. part available from our host. fix takes 10 min.
http://www.pelicanparts.com/bmw/catalog/shopcart/BE36/POR_BE36_ELswch_pg4.htm#item28
Kurt Sampara 12-05-2007 11:23 AM
It does take 10 minutes. Just a piece of advice: Crush the old switch out with vice grips. The switch self locks in place and is very difficult to remove being civil. Have fun. K.
911sculler 12-13-2007 03:56 PM
Thanks for the help everyone! I just ordered the part and will be replacing it as soon as it gets here. Thanks again for the help!
