-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Rattle comming from rear end (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/381510-rattle-comming-rear-end.html)
slimeysi 12-09-2007 04:59 AM
Hi all,
I'm hoping that someone will be able to give me a couple of pointers to the source of a rattle i have coming from the rear left of my 323 saloon.
i have replaced the rear sway bar links and checked the rear top mounts but the rattle still exists.
it is definitely suspension related. any ideas??????
1997 323 i SE Saloon - UK Spec
Yurick 12-09-2007 03:05 PM
Could be your rear trailing arm bushing or subframe bushing.
Jeron 12-09-2007 03:19 PM
Rear shock mounts are the most common. Re-double check them and Yuricks comment.
Eliminate the brake pads as a source by testing the rattle while braking. Check the exhaust hangers.
grafhky52 12-12-2007 04:20 AM
another rear shock mount suggest by jeron, what a supprise. when does it make this noise around turns over bumps leaving a stop, coming to a stop try to pinpoint when it is happening.
