Mass air flow sensor
Does the stock air flow sensor need to be replaced after so long, when at a cold start engine has an ascend then descend idle, until after revs and 5-10 minutes of running, how can I correct this??
95 318is, stock, burgundy exterior, 2 one baige interior, automatic, 180kmiles
Old 01-02-2008, 05:10 PM
A hunting idle is typically a vacuum leak after the air flow sensor. Carefully look at all rubber parts and hoses. I'd be very surprised if it was in fact the air flow sensor. gl.
Old 01-09-2008, 09:43 PM
DId you try cleaning the ICV?
92 325I 168K
Old 01-17-2008, 12:03 PM
