Greasy Member
many944s's Avatar
HELP!! E30 speedo sensor?!?
Well, I haven't had this problem until just now, though it may be because it is colder that a witch's teet outside (0 degrees).
I dropped my daughter off at daycare this morning, and the speedo worked fine. I hopped in the car about 20 minutes ago, and the speedo doesn't work?
Where is the sender for the speedo located?
Thanks,
Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 01-18-2008, 08:04 AM
The sender is located on the back side of the differential (toward the trunk).
Old 01-18-2008, 08:41 AM
Greasy Member
many944s's Avatar
Thanks!
Sure enough, one of the wires broke as soon as I pulled the connector
off the sending unit Spliced the wire and all is great.
-Nick
Old 01-18-2008, 02:52 PM
