Why no check engine light?
Just curious why I don't get a check engine light but have something so out of whack it fails the HC 185ppm and NoX 2100 ppm pretty bad.
The only time I have seen the check engine light is under hard acceleration it may blink occasionally. I hope to get back to troubleshooting it soon, maybe I can find something actually wrong. A few years ago it failed and I replaced the Engine temp sensor, O2 sensor, spark plugs, ran 2 bottles of smog pass and almost passed. Finally I replaced the cats and it passed but the HC's were still pretty high. I had a knock sensor #1 code that came back after clearing the ECM but still no CEL. Anyone know how to properly test the Mass Air Flow sensor? Mine is a Hot Film type, which I believe has a square wave output not a voltage based on resistance. Scott |
CEL flashing on acceleration sounds very familiar. I would start there. O2 maybe...
A flashing CEL, usually indicates a misfire, I am under the assumption that the light flashes to show urgency in performing service,as continous driving with a misfire, will damage cats, and or possibly cause engine damage
My recorded misfires have had a solid CEL.
I don't think he meant "flashing" but rather comes on only for a very short time then goes off. |
| All times are GMT -8. The time now is 12:51 AM. |
