Rlg4675
window/ sunroof
Hello, My 1994 325i needs a window motor . How can I tell if the car has the one touch feature as I bought the car in December and the window has not worked since I bought the car. I can hear the motor run but the window does not move. I pulled the door panel off and the regulator is in good shape and the clips are good. The motor seams as if the teeth are gone on the motor.
The sun roof works , It opens and closes but it will not raise at its rear. What could this be ?
Old 02-12-2008, 10:04 PM
Probably broken lifting cams.
Wayne's article (link below) is excellent. I used it to replace several broken bits in my sunroof assembly. VERY satisfying to make that repair myself.
http://www.pelicanparts.com/bmw/techarticles/101-Projects-78-Sunroof/101-Projects-78-Sunroof.htm
David Frost
Formerly smitten by a 1993 325i Sport with 170K+ miles. Now infatuated with an Audi A3 2.0T DSG.
Old 02-13-2008, 08:42 AM
