Im with Bill.
jbholland4's Avatar
Send a message via AIM to jbholland4
Air Bag light is on & No horn
The airbag light stays on all the time... and the horn does not work... Where do i start looking to fix the problem??? I dont think anything with the steering column has been unplugged and i dont know where or which fuse to check... ANY ADVICE???
Thank God for curves... Great on women and in cars.
Old 03-15-2008, 06:32 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
slip ring (#2 in pic) inside the steering wheel is bad. I had this happen a coupla months ago @ 150k miles. SRS light on on dash and horn gone. Clicking or crunching when you turn the wheel. Check the codes. You will get a low voltage code for the SRS IIRC. I found a used replacement. easy fix if you turn wrneches.
Here's some reading, scroll down on the webpage, its at bottom.
http://bmwnut.blogspot.com/2006/02/e36-325i325is328i328is318i318ism3-slip.html
I might have one in a spare steering wheel I got on here a while back. Ill check in the garage in the am if you are interested unless you want to go new ($160).
http://www.realoem.com/bmw/showparts.do?model=BJ53&mospid=47475&btnr=32_0687&hg=32&fg=35
Good Luck
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-15-2008, 10:08 PM
Send a message via AIM to Bear
SRS Light
SCOTITUDE is right on, it is the clock spring and I had to replace one on my '88 750 and the company did one on my '96 Caravan, problem solved
Old 03-16-2008, 07:12 AM
Im with Bill.
jbholland4's Avatar
I will look into that.... My steering is not stiff nor does it make any noise, then again it could be just COMPLETLY shot
Old 03-16-2008, 09:55 AM
