High/low beams
Hi, I have a 90 325i, when I turn on the head lights the low beams work fine, when I switch on the high beams, the passenger side lights go out. The drivers side lights work as they should. All the bulbs are good, and ideas, thanks.
Old 04-12-2008, 02:48 PM
Relay, high/low beam switch?
Old 04-13-2008, 08:35 AM
High Beams
Hi, found the problem, I broke my own rule, check the easiest things first, it was a blown fuse for the high beam right side. It has the orig fuses so they are hard to see if they are good etc.(at least for me) all is good now, thanks.
Old 04-13-2008, 01:47 PM
