Pelican Parts Technical BBS
Pelican Parts Technical BBS (http://forums.pelicanparts.com/)
-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Jumping Tac (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/406261-jumping-tac.html)
traub 04-27-2008 03:31 PM
Jumping Tac
87 325i - 148,000 miles - Automatic - Runs fine, but the tac jumps up and down. It will just sit there at zero, then jump up to 2,000 rpm or what ever speed I'm going, then a second later, it drops down to zero again. Sometimes it works for a while... say 15 20 minutes. It acts like it's just losing power intermittently? Before I go pulling the dash apart to pull the cluster, it would be nice to hear if somebody else has had the same problem.
Yurick 04-28-2008 04:44 AM
Sounds like you need to change batteries in your SI board.
traub 04-28-2008 08:05 AM
Thanks... but I plead ignorance.....SI? as in the circuit board on the back of the instrument cluster?
Yurick 04-28-2008 10:28 AM
Bingo...
alpine325 04-28-2008 11:49 PM
UH I would say its a loose connection in the cluster. All you have to do is tap the on the cluster if it jumps then its a loose connection. But it also could be a bad tachometer. Question are the lights on for oil/inspection? If so get them reset if they come back on then the si batteries are bad if not then its just a loose connection.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website
