97 328i glove box support
I have just finished replacing the evaporator (not a difficult job, just tedious) and am reasembling the dash.
I was careful when I was taking things apart but have run into a snag involving the glove box support. At the lower left of the welded bracket where it meets the transmission tunnel there is a gap of about an inch. If I try to bolt the bracket into place it causes all sorts of problems with the passenger SRS and glove box alignment as it causes the glove support assemby to twist. I am assuming that there is supposed to be some sort of spacer to fill the gap, but dang if I can find one (as I said I am usually very good about this sort of thing) I have looked at the RealOEM parts diargram, but it does not show a spacer. Can anyone help me with a part number of a picture? Thanks. |
fixed, space was in my head
Turns out that the glove box support bracket has a third mounting stud that is midway between the right side of the dash and the center console.
I didn't remember taking it out. Probably because I was lying on my back and contorted and in pain. Anyway, that's how it goes. If anyone ever needs some advice on how to R&R their evaporator, send me an e-mail and I can probably save you a few hours. One thing I found out was that you do not need to remove the "fracture bolts" on the steering column as is suggested. Tuns out that there is plently of play and you just need to shove the steel support bracket down and to the side. Thanks. |
Sounds like a big job. Glad you got it worked out.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
