 clutch whining - to replace or not to replace
		on my 96-318ti, with clutch disengaged there is a whining along with a strong in-out vibration at the clutch pedal; engaged, all is normal. There has not been any clutch slippage. Mileage is about 175k and I believe it is original clutch.
	is it best just to replace the whole clutch? is there an ability to grease the bearing? without tearing it all apart.  |
 Clutch Whining
		It does sound like it may be a throwout bearing, and it is not possible to lube a throwout bearing.  175k is not bad service for a clutch.  If you are going to the work to drop the tranny, I would definitely replace the clutch, pressure plate, pilot, and throwout while I was in there, even if it still has some life in it.
	I don't know anything of 318s, but on some cars, it is a real good idea to replace the rear main seal beneath the flywheel when you do the clutch. The other thing to research ( I don't know the answer) is whether your 318 might have a dual mass flywheel. If it does, and the flywheel is failing, the clutch job can get pricey. I am told that one symptom of a failing dual mass flywheel is a chattering sound as the engine spins down after you turn off the key.  |
 thanks again for the pointers. I haven't had the chatter down on shut off, though the "feeling" of engaging the clutch pedal seems like side heavy causing a wobbling feel like mass has shifted
 Clutch
		I looked at the parts list, and you do have a dual mass flywheel.  That runs $600 on line, so let's hope you don't need it.
	I have had a 'rumble' feel through my clutch pedal since I bought my second e36 several years ago. I put a new clutch in it right after I bought it. The rumble did not change. I have put another 50k miles on the car, and it is still the same. My BMW specialist mechanic cannot tell me what might be causing it.  |
 If you pull the tranny put in a new clutch.  You might leave the flywheel but 175k is a lot of miles.
| All times are GMT -8. The time now is 03:23 AM. |
