Unhappy 2 problems
HI guys i have a 328i, - 1998 and today my sun roof stop working staying in the open position, how can i fix this.-
Second, my radiator is loosing cooling for the las t 2 days I have to place cooling in the resv tank what can be the problem?.-
Old 07-16-2008, 04:48 PM
I think the '101 Projects' book has some good discussions on sunroof repair. I have not needed to use them yet. That book is a good investment. In the short term, I would check the fuse. You can check the roof switch by trying to close the sunroof by holding the key in the lock position in the driver door (rolls up windows and closes sunroof)
I have been looking for a mystery cooling water leak for months. I even bought a dye kit and ultraviolet light. The dye works great but the leak is very slow and the water sprays all over the place when the car is running so I have not found the leak yet. It is impossible to see the weep hole on the bottom of the water pump on these cars, so if there is no play in the water pump shaft, it is hard to know if the water pump is shot without tearing things apart.
Old 07-17-2008, 06:32 AM
