Angry 325i Starter Issues
Just from working w/ it today, finally got it started, but only after wiggling around a few of the Relay Switches I think that is the correct nomenclature anyways, the larger sized square fuses w/ 4, 5 or 7 plugs, in the fuse box. Tried pulling out each one individually to check for any signs of corrosion or a loose connection--none--and to see if it would affect the ignition process, but the car started on its own several times, every time. Now that I finally got it back home, it does not want to start again.
Last edited by Reardon_san; 12-11-2008 at 04:28 PM.. Reason: the Starter works after all...
Old 12-11-2008, 09:49 AM
