Bijan's Avatar
Send a message via Yahoo to Bijan
Hesitation problem
On my 1988 325 I am having a hesitation problem. As I am driving (not always but most of the time more when the car is warmed up) and the RPM reaches around 2000 the car wants to stall and then it is fine then repeats every second. I am suspecting the fuel filter and planing to change that tomorrow . Could that be the problem?
Old 12-15-2008, 01:06 PM
Could be, but you may also want to look for air leaks.
The rubber intake elbow is a good place to start. They get cracks.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 12-17-2008, 05:39 PM
It could also be a worn out spot of the variable resistor inside the air flow meter. if no cracks are found, and the pressure is good, i'd try getting a used meter to swap with, also check the TPS on the throttle body. the switch is idle, cruise and full throttle positions, and if it intermitently cuts out it might act that way. but if its mostly upon cruising or mild acceleration i'd look to the AFM.
Old 01-13-2009, 12:04 AM
