-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Ignition Driver Transistor - E36 DME - Source or replacement types? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/449442-ignition-driver-transistor-e36-dme-source-replacement-types.html)
68GT500 01-03-2009 01:03 PM
Hello all,
my daughters 316i (7/95 Europe) had one shorted coil (in the block of four).
I replaced the coil pack, but still #4 has no spark.
Diagnostics gets error: "ignition driver"
I checked the DME and found that one of the four driver transistors is blown.
I havenŽt been able to find any infos on this thing nor a replacement type.
Its marked 30011.
Please help me get this thing running again..SmileWavy
68GT500 01-09-2009 08:04 AM
Ok, i found it.
IŽll post the result for the benefit of everyone ..
The transistor that worked for me is a BU323Z.
Its is pin compatible to the org. Bosch 30011
It also is a NPN Darlington with an integrated 360V Clamp - specifically designed for electronic ignitions.
Car has been running severals days now - that is not enough time to call it really fixed - IŽll let you all know if a new problems should occur.
What seems odd to me is that Bosch or BMW would not integrate some sort of fuse to reduce the harm done by a shorted coil.
Charging a customer many hundred $ for a new DME - when all that is needed is a lousy transistor valued at less than $5,- (Or a fuse valued at some cents..)
No wonder the auto industry is hurting - I donŽt like beeing ripped off. :(
