tools
Hi
are there any special tools required when changing the timing belt, water pump thermostat etc, other than the normal spanners or sockets?. |
Hello, and welcome to the board. Here's a link to another enthusiast that has written about the jobs you want to do.
http://www.esatclear.ie/~bpurcell/318ismaintenance.html#waterpump His method for removing the fan does work, I've used it myself. This will save you money over the special tool people mention occasionally for removing the fan. Good luck, it's rather straight forward really, the only problems I encountered were removing the waterpump from the engine block, it was a bit stubborn.
David Dolan 1995 993 Carrera 4 India Red 1979 911 SC Targa Metallic Black |
hi thanks for that - there's some good info there,
I'm guessing it will be very similar for the 6 cyl models cheers Gordon |
