fuel and temp gauge flicker
I have read reasons for both gauges to have these flicker problems but I am hoping that they are both being caused by the same thing. They both flicker intermittently. I can tap on the clear gauge cover and they bounce around. Do you think its the battery on the cluster or something else? Or not related to each other?
1988 325 super eta
Old 02-27-2009, 08:34 PM
I took the cluster out and the batteries are checking out ok. Is it possible that the board is bad or the entire cluster needs replaced? I hope its not the whole thing, I would like to keep the mileage and everything original.
Oh, while I was taking it apart, I have a single white wire hanging there and I dont know where to put it back. The end if it was stripped back, so it was shoved somewhere...............Thanks
1988 325 super eta
Old 03-11-2009, 09:28 PM
I had a problem with my temperature gauge that was caused by a loose ground connection. I ran another ground from one of the brass screws in the back of the instruments to a bolt that ran into the chassis below the instruments and it fixed the problem.
alan
Old 03-12-2009, 03:12 PM
