-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   ignition problem (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/472414-ignition-problem.html)
Yagamo 05-03-2009 10:14 AM
ignition problem
Is there any reset for the problem of key spinning in ignition switch ? 1997 325I
Manolito 05-03-2009 09:46 PM
You need a new lock cylinder. In theory, you can remove the lock from the housing with just a thick paper clip or a small drill bit, if you turn the key to exactly the right position so that when you poke the wire down alongside the lock, it releases the spring-loaded latch that holds the lock in.
In PRACTICE, very few of us have been successful in getting out our locks once they were 10+ years old.
After you buy a new lock and housing, you will find that a new lock comes out easily, but even after practicing on the new one, you still won't be able to get the old one apart.
Search the forum. This topic has been discussed. once fairly recently.
Wyvern 11-16-2009 07:00 PM
bit late to the party ...but if anyone else is looking for the answer ...
Google "bmw ignition lock" ... there is a utube vid that shows the fix
mikecgolf 11-17-2009 05:35 AM
Mine does this also
96 328IC 89K miles.
The key spins around sometimes but will then conect on the next revolution and start up.
What are the problems with the new ignition lock and the chip in the key?
