99 bmw 323is
i had my 99' 323is scanned and the o2 sensor came up as 222 does anyone which sensor this is?
Id try this site http://www.obd-codes.com/trouble_codes/
your obd2 with the year,, i reciently had similar problmes with my 97 M3, What i was told was there is bank 1 and 2 and sensor 1 and 2, not sure if yours is a 6 cyc or 4 but for the 6 cyc there is two tracks coming off the block -- bank 1 is the track closests to the driver and bank 2 is on the other side -- sensor 1 is pre cat and sensor 2 is post cat whatever the malfunction is with the o2 -- it should tell you mine was (( heater malfunction bank 1 sensor 2 )) so thus it would be the track closests to the driver and the post cat o2 Hope this helps |
