SprtnBit's Avatar
Question DMF resurface?
1993 325i
In this article Pelican parts mentions getting a dual-mass flywheel resurfaced; however I can not find a location that will do this. In fact most of these places say that it is not possible. Is this true?
Old 06-18-2009, 02:38 PM
So far as I know, you can cut up the glaze by manually sanding the surface a bit, but you cannot machine it flat like you could with a conventional flywheel.
On a 16 year-old car, you might want to consider replacing it as a preventative maintenance measure even if it is not chattering yet if you intend to own the car for a long time.
Old 06-19-2009, 06:27 AM
Tags
flywheel , resurface , transmission
