anti theft system 93-325is
Could someone tell me how to disarm ,or what could cause the warning LED to stop blinking,now it want start,and I think its the theft system causing the problem,car was running perfect,gone 2 days came back,car want start,---------js
Old 08-14-2009, 08:18 PM
crazeetowntattoos
crazeetowntatto's Avatar
did someone set the code? if so you gotta know the code or contact bmw to get unlock code. before you you get the motor cranking turn your key to the on position look down at the computer and push the code button it should have 4 dashes on it. you use the 4 number buttons on the left to put in the code then hit the set button to enter it. if you try to open the hood does your horn start beeping?
Old 08-15-2009, 06:41 AM
