loud sound please help
94 318is
loud humming at certain rpms on DECELL i can hear it very very faint on acc. its a loud humming rattle . very very loud lose something? i was thinking flex disk but thats only on accl correct?
i just replaced entire motor and had a new flywheel/clutch/pilot/throwout. put in by a shop.
its an aftermarket lightweight flywheel
i just got my car working then this loud noise!!!
usauly dosnt start till 3d gear 3.5k decell or 4th gear 5th does it around 75mph decell.
HELP
Old 08-15-2009, 12:01 AM
Jeron's Avatar
Its your lightweight flywheel. The noise is normal and wont hurt anything.
You can try the thicker gearbox oil but it doenst work very well and it may make shifting in the winter more difficult.
http://www.uucmotorwerks.com/html_techtip/techtips/tranny_rattle.htm
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-17-2009, 08:23 AM
even if its not just at idle like that website says
Old 08-18-2009, 02:56 PM
noise on decell in higher speeds rpms 3d gear around 35 mph decell 4thgear around 45 mph decell and 65 70 decell in 5th. i just replaced the guibo today with no change
Old 08-18-2009, 03:20 PM
Jeron's Avatar
The deceleration noises you hear are also caused by the lightweight flywheel. The problem isnt that its lightweight but rather because there is no vibration dampening as ther eis in the stock Dual mass fly.
I have the same effect. When decelerating there are resonance points which have a very noticeable noise and vibration.
Did you have stock motor and tranny mounts?
Old 08-21-2009, 11:43 AM
new oem motor mounts and original tranny mounts.
and its an unsprung clutch
Old 08-21-2009, 01:49 PM
