7401 help
`95 740i 9degrees this a.m. doors opened normal, started car, drivers door wouldn`t close all the way and engage, pulled from inside, closed then would not open. got out pas. side, back doors normal. tried key, worked normal, locks go up & down ok tried key lock on console up & down ok, dr. door won`t open. then closed pas. door, it now won`t open from in or out. both engaged tight. back doors work normally. neither front door will open. car starts fine. just doors problem. open close function works fine both with remote, key in dr. door & from console. just can`t open doors. HELP PLEASE? CT owner. Had wife take our tahoe while I try to wrestle with this issue. J. TOLLAND CT
Old 01-03-2010, 09:50 AM
