1993 325i E36 power seat release
I have a 1993 325i E36 with power seats (forward/back, up/down, recline, no heaters). The passenger forward/back drive motor appears to have failed. The seat is sitting in the rearward most position. Step 1 to repair is to remove the seat. To do that I need to access the two rear mounting bolts in the rails. But I cannot access them because I can't move the seat forward. Anyone know if there is a manual release for the seat forward/back rail movement? Or does anyone have a suggestion for how to proceed with this situation?
Old 12-20-2009, 07:02 AM
Follow-up
So here's the answer (in the interest of closure) ... There are a pair of torx screws that attach the seat base to each of the rails in front. The seat bottom hinges in the back by design. After removing the 4 torx screws (not real accessible on the inside edge of the seat but doable), the seat can be hinged up/back which exposed the front motors and the flex drive cables. In hinging it up, the drive cables pull out from the rail gear box mechanisms. Once in that condition you can use a suitable size philips or flat blade screw driver to insert into each rail gear box mechanism (where the drive cables insert). It takes a while but you can then manually move the seat forward to reveal the rear seat rail bolts. Having first removed the front bolts, the seat could then be removed. As it turns out, my problem was a burnt contact inside the seat switch. Strangely, testing the switch with a volt meter suggested the forward/back switch action was working correctly. But using the front up/down switch as a check, it showed that the front/back motor was working fine. There was just enough continuity to allow 12v to pass but enough resistance due to the burned contact surfaces that not enough amperage could pass to spin the motor. Turns out you do not need to pull the seat to remove the switch box (so in the end I never did actually pull the whole seat out). Out of curiosity I opened up the switch box and found that the contacts associated with the forward/back switching were badly burned. I found a guaranteed/used switch on eBay for $28 delivered and I am back in business.
Old 12-23-2009, 08:10 AM
I'm glad I came across your post as I've posted at two other forums with no answer to the problem.
After taking my wife’s 1998 328i 4 door to the car wash this morning, I found the passenger seat slid all the way back and the backrest partially reclined. Now the seat does not react to any of the switches. The fuse has +12v to it and is good. I also tried exchanging fuse #5 (passenger power seat) with #40, the one for the driver's side power seat, which works fine. Still, it's as if the seat lost all power.
I am surprised that BMW would have engineered their power seats in a way that would render them "locked in" and completely unserviceable, should they fail in a position other than the middle of the rail track (forward/back adjustment).
Do you happen to have any pictures of where to find those torx screws? My seat is also in the low position which will make it really hard to get underneath.
Anyway, thanks for this post. It gives me something else to try.
Old 08-16-2010, 09:14 AM
Update: I reached under from the back and checked to see if everything was plugged in, and it was. So I pressed 'em in a little and then tried the seat again. Bingo. Something had pulled out enough to render the seat powerless.
Old 08-16-2010, 03:27 PM
Tags
325i , e36 , manual release , power seats , seat rails
