-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Window not working (1994 325ic) (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/552946-window-not-working-1994-325ic.html)
Bijan 07-13-2010 07:31 AM
My driver side front window st oped working a couple of days ago. It is fully closed (luckily). It doesn't come down using either the switch dedicated to it or using the switch that works all the windows at once. Prior to this happening for about 6 months the feature that lowers the window a tiny bit when you depress the handle stopped working. I am not sure if one has to do with the other. Any help will be appreciated very much.
Two Rivers 07-19-2010 07:46 PM
The motor and control for the drop and lift function are all in one. There not cheep and in the door.Not to bad to replace if you have the patience.They can be a little tricky the first time you do one.
