AutoX
E36 Electrical Issue
My daughter has 1997 328 IC this afternoon when she turned off the ignition the radio and all dash display stayed on. I had her disconnect the battery and reconnect it when she pushed in the clutch the radio shut off. Any ideas?
Old 08-10-2010, 04:30 PM
Hello!
it might be a main ignition feed to your cluster. which probably wont affect anything else in your car. or it could be an internal problem in your cluster or a ground to your cluster. it should be tested and diagnosed properly by someone with electrical experience
Mustang parts
Old 08-12-2010, 07:12 AM
AutoX
Thank you, ya i took it to 3D Auto in Hudson NH they are a high quality BMW specialty shop. I go there when i can't figure things out.
Old 08-13-2010, 08:31 AM
