Matt
Bulb replacement - Foglamp & sidemarker
1992 325i Cabrio M-Technic pkg - Bulb replacements:
Foglamp - the H3? Sidemarker - How does one access the bulb? |
Matt
ZKW foglamp
The Foglamp is the ZKW assembly (your part #63-17-1-385-946-M229)
Matt
found the answer on sidemarkers through bimmerforum DIY
Matt
Done
ZKW foglamp is M3. Don't need to pull the entire lamp as replacement pieces apparently aren't availalbe. One phillips screw will permit access to the bulb. Pulled mine (4 8mm screws), cleaned, applied adhesive to rubber gasket, reinstalled with cracked lense (better'n $180). Got light.
