kyle (guest)
Guest
Posts: n/a
i jusdt replaced my brake light switch and now they wont turn off at all ?? what should i do what would cause them to be on constantly thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Brake Switch Replacement
Old 03-20-2011, 11:27 PM
Author of "101 Projects"
Wayne 962's Avatar
Sounds like the switch isn't seated all the way in it's mount, which may cause it to be "on" all the time. I would check the seating of the switch, and compare it to the photos in the article.
- Wayne
Old 03-20-2011, 11:28 PM
bostongrun
Take the brake light switch bracket off. It goes a lot better. You may have bent the bracket. You can take it off and re-bend it back to the correct shape in a bench vise.
Old 03-21-2011, 09:11 PM
