Rachid (guest)
Guest
Posts: n/a
Hi, I have a BMW 1998 323i convertible the top wont open can you please tell me what steps to do to check why it doesn't open thanks for your time and help.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Convertible Top Adjustment and Repair
Old 02-06-2011, 03:22 AM
Author of "101 Projects"
Wayne 962's Avatar
There are a few things that can go wrong with the convertible roof. Firstly, you must make sure that your switches are all operating properly. The one switch that was an issue with my car was the trunk switch. If the car thinks the trunk is open, then it won't lower the roof. This switch can fail from years of use, and it is also susceptible to problems with the trunk wiring (see Figure 2 in this article: http://www.pelicanparts.com/bmw/techarticles/101-Projects-82-Electrical-Problems/101-Projects-82-Electrical-Problems.htm) ]http://www.pelicanparts.com/bmw/techarticles/101-Projects-82-Electrical-Problems/101-Projects-82-Electrical-Problems.htm) [/url] I would start looking there first. Also, if your windows are stuck or non-operational, then the roof will not open either.
- Wayne
