Guest
Posts: n/a
Hello,I have problem with my 318is cupe from 1994 ,DME found full with water,engine can not ignite,fuel pump is Ok,but sparks dosent come every time so engine can not start,
my mechanics told me that DME is not OK ,and after 3 diferent second hand DME replaced same problem every time,Please help for some advice due its very hard to find same DME and my mechanic do not want to make diagnostic due he is surre that DME is not OK?Bosh no. 0 261 203 590 BMW no.1247786 WBA BE5100JG26700801E Also to add that DME after drying found without any burned parts,and has properly cleaned by mechanic __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW DME Motronic ECU Swap / Repair |
Author of "101 Projects"
This is a tough one. The DME definitely had a problem, as they are not supposed to be full of water. Starting the car with a wet DME will most likely damage the unit. Unfortunately, it may have damaged some other stuff on the car as well when you tried to start it wet. I would check the crank and camshaft sensors, as the engine will not fire spark without these working properly. Also, check the connector to the DME - if that was wet as well, then there may be some rust in there that may be causing the connections from the sensors, coils, and other components to fail to be connected to the DME. Good luck!
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
