donben (guest)
Guest
Posts: n/a
bmw 316i 1999 compact 1.9lts is very thirsty, does 20miles to gallon. what could be the possible cause
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 02-14-2011, 12:31 AM
Author of "101 Projects"
Wayne 962's Avatar
The car will typically tell you if there is a problem, check the codes using the tech article I wrote here: http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm If the mixture is off, or an O2 sensor is faulty, the codes should show it.
- Wayne
