Guest
Posts: n/a
Got a 1984 318i. It wont start unless I give it 1/2 throttle or more while turning over the engine in which case it starts up fairly quickly. It will die when I let off the gas and there is no idle whatsoever. Also, occasionally when keeping the throttle steady around 2500 the car will randomly bog down unless I give it more gas. I'm hoping for just a vacuum issue.
Thanks! __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Idle Speed Troubleshooting |
Author of "101 Projects"
Yes, this could be a vacuum issue, or it could be a clogged idle control valve. I would inspect the valve and clean it, and also check all of your hoses / boots for vacuum leaks.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
