Jenh52384 (guest)
Guest
Posts: n/a
HI, I am trying to purchase a hood emblem for my BMW 06 325i, it came off last month. It seems that it was stuck on with an adhesive and it has 4 grommet holes that are very small. I see that the one that is on here only has 2. Do you have the 4 holed adhesive hood emblem?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing Your Roundel Emblem...
Old 02-16-2011, 12:37 AM
Author of "101 Projects"
Wayne 962's Avatar
This is a common question. What actually happened with your car is that the emblem itself separated, and what you're looking at is the bottom of the emblem, still stuck to the car. What you need to do is remove this bottom piece, and then you will see the two holes underneath, where you install the new emblem. New emblems are actually two pieces - the bottom base piece, and the top blue/white part.
- Wayne
