DanielT (guest)
Guest
Posts: n/a
Hi i've recently bought a 96' BMW 318ti, i've had a problem with it jumping out of second when its cold and grinding a bit, i had a manual trans place take a look and they told me an oil change might help, the gears seem a bit smoother now but im still having the problem, another place recommended changing the bushings before looking into the syncro, any thoughts ?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Shift Bushings
Old 02-21-2011, 12:37 AM
Author of "101 Projects"
Wayne 962's Avatar
This is a typical problem associated with worn synchros. Eventually, you will have to have the synchros in the transmission replaced. But, in the meantime you might want to try a gear lube that has *less* slippery properties. The theory behind this is that you're syncrho is worn and slippery enough already, so using a super-slick oil will only make the problem worse. Unfortunately, I don't have any good recommendations at this time for any specific oil.
- Wayne
