I have a 2002 325i. Getting code 1085 running lean. Could it be a fuel filter causing the problem. It is the original fuel filter.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Reading BMW Fuel Injection Fault Codes |
Hmm, it might be caused by a clogged filter, but I would guess probably not. Still, changing the filter is probably something you want to do, and it's also probably one of the easiest things to do, so I would indeed start there and then see if the code continues to be triggered.
- Wayne |
| All times are GMT -8. The time now is 07:34 AM. |
