-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   When to change automatic transmission fluid? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/594224-when-change-automatic-transmission-fluid.html)
STORMIN (guest) 02-27-2011 09:56 PM
WHEN SHOULD THE TRAN OIL BE CHANGED IN A 2006 325I ? iS lUCAS SYN THE BEST?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Automatic Transmission Fluid Change
Wayne 962 02-27-2011 09:56 PM
I like to change fluid at about 60,000 miles on a relatively new car. I'm not sure about the Lucas brand - you must make sure that the fluid type is matched to the plate typically located on the side of the transmission.
- Wayne
