Rrrockhound's Avatar
Clutch job cost
Can anybody tell me what I should expect to pay an independent mechanic to replace the clutch in my 87 325?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 03-03-2011, 05:31 PM
I would say give or take $500.
Old 03-04-2011, 06:42 AM
I have had to pay for two clutch replacements through the years that I could not do myself for one reason or another. I paid about $900 each time.
This assumes that your flywheel is in good shape.
Consider getting a new rear main seal at the same time. I did a clutch job once at 175k miles and didn't do the rear main because it was nice and dry. 50k miles later the rear main started leaking. I felt pretty dumb.
Old 03-04-2011, 06:12 PM
Thanks guys. That helps.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 03-05-2011, 10:17 AM
Its not that hard to do a clutch change on these cars.......as long as you can get to the top gearbox to engine bolts (better with an assistant) its a case of systematically removing the prop shaft, all the bolts aroudn the bell housing, the gear stick linkage and connections etc.......and supporting the gerabox whilst you remove the rear mounts......then slide it off and down......
Good time to renew all the cheap bushes and links on the transmission
The rubber Guido thing
Transmission mounts
Transmission oil
Check the starter motor
Main seal is a good plan to check, but not easy to change
Old 03-10-2011, 05:08 AM
