-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   How many O2 sensors on the 1998 328is? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/595763-how-many-o2-sensors-1998-328is.html)
mabeamer328 03-08-2011 11:29 AM
HOw many oxygen sensors are on a 98 328IS? I'me getting differing information from an after market parts company.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Wayne 962 03-08-2011 11:29 AM
For the US market, there should be a total of four sensors, and they all appear to have the same part number: 11-78-1-427-884-M209.
- Wayne
bostogrun 03-08-2011 08:24 PM
Don't mess with them unless you have a CEL code. Sometimes, they dont come out so easy especially if they have been in there for years. If you trash a sensor trying to get it out you go beyond the point of no return. Then you will be removing the whole exhaust system or even worse an exhaust manifold trying to get it out. Make sure that you use a o2 socket. It can be a real b_____h getting just the right access and leverage to the two in the exhaust manifold. For some reason 02 sensors have a soft hex unlike a spark plug and round off super easy. Once the hex is rounded your going to have to remove exhaust components. Many exhaust shops consider o2 sensors unremovable.
BMW and many vendors recommend changing them after 100k as preventative maintenance or as part of a "tune up" If a car has been well maintained ( in this case meaning frequent air filter changes) the sensors can last the life of the car. The sensors are actually voltage generators develop a wave form usually between .2 and .9 volts. The CPU monitors the sensor output and adjusts the fuel supply to injectors. The CPU is pretty darn good, almost too sensitive, regarding detecting problems with sensors. Many times they trigger a CEL with no driveability issues because the CPU is so sensitive. Usually, a rich condion is associated with bad sensors. You will notice poor fuel economy, rough idle, the smell of gas under the hood and diluted oil. The O2 sensors don't have any thing to do with starting because they don't come into play untill after the car is in "closed loop" i.e. fully warmed up/
