Kymbr (guest)
Guest
Posts: n/a
The passenger seat is stuck in the highest up position and it won't go up or down, I don't hear the motor running. Is there a manual overide so I can keep the seat in the lower position?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Power Seat Repair
Old 03-20-2011, 10:35 PM
Author of "101 Projects"
Wayne 962's Avatar
If you remove the seat, then you can manually turn over the motor using a drill or even your hand. Or, you can apply 12V directly to the motor to make it move. More likely, your switch is defective, and you can simply fix the problem by replacing the swtich unit.
- Wayne
