slick (guest)
Guest
Posts: n/a
What's up I have a 95 325I its leaking coolant near the fire wall I got under the car and the coolant is driping down the transmission near the torque converter do have any idea where it might be leaking from?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Heater Valve Cleaning/Flushing
Old 03-25-2011, 10:58 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, the water leaks at the back of the engines are near where the heater valve and hoses are that feed hot water into the heater system for the passenger compartment. Something is leaking back there, possibly the heater valve. You need to go in there and check it out (it may only be an old hose).
- Wayne
