-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   OBD Computer issues... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/599208-obd-computer-issues.html)
327 (guest) 03-26-2011 12:20 AM
Followed directions above and 18 button works after a fashion. I do experience the following problems- after only 10-15 miles
a-Mph is approx 30% of speedo reading
b-brake lite failure warning but all lites function and are stock
C- range, mph and mpg do not work
My logic tells me that the speedo input functions but needs a setting changed.
The brake light warning is perplexing
Could I be not getting the info from the fuel gauge
will do more trouble shooting next weekend
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW On Board Computer Retrofit / Conversion
Wayne 962 03-26-2011 12:20 AM
I'm not sure about the other issues, but the brake lamp warning circuit is a common question. The circuit in these cars is a dual-switch circuit (one for backup I suppose). So, if one half of the switch breaks, the lights will still operate, but it will give you a warning on the computer. Simply replaced the pedal switch, and the message should go away.
- Wayne
